NanoPI M4 Hardware Features?
I am considering buying a M4 + Sata Hat for building a NAS.
Since I already had several ARM devices (RPi3, ReadyNAS RN104) which all are missing standby:
Does the M4 offer standby?
And regarding the SATA Hat: It delivers Sata 6 Gbps. But what PCIe Standard is brought by the M4? Is it all Software / Firmware?
We've got 4x Sata but only 2x PCIe. So there is no way 4x6 Gps fit into 2x PCIe, regardless which version.
Does multiplexing of 4xSata into 2x PCIe work fine?
thanks
I found the specs of the marvel 88se9215 which say, that it uses a single PCIe 2.0 lane and thus is limited to 500MB/s (5Gb/s) which is less than the speed of a single SATA-3 channel. There are variants which use 2 lanes but looks like Friendlyarm saved on costs...
i also have the same problem
import RPi.GPIO as GPIO
RuntimeError: This module can only be run on a NanoPi NEO/NEO2. Thanks
