OLED/LCD display options (non-HDMI)
Hi there,
For the NEO4 hardware, we need to use both HDMI for an external screen AND want to use an OLED or LCD touch display.
What connector options are available on the NEO4 for touch OLED/LCD displays ?
thanks
Matt
The NEO4 only has HDMI.
The NanoPi M4 has got MIPI DSI + HDMI. I don`t know if you can use both at the same time.
It`s possible to connect a video card to the NEO4/M4 with the PCIe. But that would be a lot of trouble for this.
I2C displays should work like on any other board but not sure if support is enabled by default.
any change o the oficial Raspberry pi display work on mipi-dsi conector of M4 and T4?
Nano Pi M4 connection of the display via MIPI-DSI ... does it generally technically have a ready solution?
Is it possible to point to the finished display or adapter for it (maybe a link).
For other boards, there are ready-made solutions, for example, the "S430" display, which is compatible with (for example) Nano Pi S2.
For the T4 card, there is an excellent “HD702E” display that can be connected "ON ONE WIRE", it's great!
What should the happy owners of the Nano Pi M4 board do?
Sincerely, Pavel.
Any updates on DSI displays for the M4 ?
