Where to find the Linux kernel for 5.1?
Where can I find the Linux kernel for Android 5.1
I only have the source for Android and a binary for the uimage on the SD card.
I can build the Android source but I also need to add some features to the kernel so I need to build this from source too.
I've check on GITHUB and found nothing for the S5P6818 processor.
I actually found it and have been able to build it.
For anyone else looking for this, it's on the Wiki page for the NanoPC-T3 and you just have to follow the instruction to download this onto your machine and then configure and build. It requires a bit of work to use it as the build is bigger than the one supplied with the flasher. It has some drivers missing. I'll post back here what changes I do to get it working later in case anyone else is interested.
