Using WiringNP for a NanoPi Duo?
The NanoPi Duo wiki page:
http://wiki.friendlyarm.com/wiki/index. ... h_WiringNP
directs the user to the WiringNP wiki page:
http://wiki.friendlyarm.com/wiki/index. ... ing_with_C
The WiringNP page provides directions for building for the NanpPi Neo and for the NanoPi M1, but not for the NanoPi Duo.
Is this a solved problem, or should just use the Neo and/or M1 versions and ignore the pin numbers?
Followup:
The instructions on the wiki do not state this, but you shold follow the instructions for the Neo, not the M1, when you build. Then the generated code will read the file /sys/class/sunxi_info to determine the
board type. That's great, but the result from
gpio readall has the wrong physical pin numbers:
pi@NanoPi-Duo:~/WiringNP/gpio$ sudo ./gpio readall
 +-----+-----+----------+------+---+-NanoPi-Duo--+------+----------+-----+-----+
 | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
 |     |     |    MIC_N |      |   |  1 || 2  |   |      | EPhySPD  |     |     |
 |     |     |    MIC_P |      |   |  3 || 4  |   |      | EPhyLinK |     |     |
 |     |     | LineOutR |      |   |  5 || 6  |   |      | EPhyTXP  |     |     |
 |     |     | LineOutL |      |   |  7 || 8  |   |      | EPhyTXN  |     |     |
 |     |     |     CVBS |      |   |  9 || 10 |   |      | EPhyRXP  |     |     |
 | 198 |   8 |   GPIOG6 | ALT5 | 0 | 11 || 12 |   |      | EPhyRXN  |     |     |
 | 199 |   9 |   GPIOG7 | ALT5 | 0 | 13 || 14 |   |      | USB-DP2  |     |     |
 |  15 |   7 |  GPIOA15 | ALT4 | 0 | 15 || 16 |   |      | USB-DM2  |     |     |
 |  16 |   0 |  GPIOA16 | ALT4 | 0 | 17 || 18 |   |      | USB-DP3  |     |     |
 |  14 |   2 |  GPIOA14 | ALT4 | 0 | 19 || 20 |   |      | USB-DM3  |     |     |
 |  13 |   3 |  GPIOA13 | ALT4 | 0 | 21 || 22 | 0 |  OFF | GPIOG11  | 16  | 203 |
 |  12 |  12 |  GPIOA12 | ALT5 | 0 | 23 || 24 | 0 |   IN | GPIOL11  | 18  | -1  |
 |  11 |  13 |  GPIOA11 | ALT5 | 0 | 25 || 26 |   |      | 0v       |     |     |
 |     |     |       0v |      |   | 27 || 28 |   |      | 3.3v     |     |     |
 |   4 |  14 |   GPIOA4 | ALT5 | 0 | 29 || 30 |   |      | 5v       |     |     |
 |   5 |  15 |   GPIOA5 | ALT5 | 0 | 31 || 32 |   |      | 5v       |     |     |
