Rooting NanoPC-T4???
Posted: Mon Mar 25, 2019 9:04 am
by Tiemichael
How do I root the NanoPC-T4?
From another post relating to NanoPI-T4 it says compile with 'Userdebug' - but this does not seem true.
My Build Number says: nanopc_t4-userdebug 8.1.0 ...
I either need a way to build the NanoPC-T4 rooted, or a way to root it afterwards.
If this is not possible, I most likely bought the wrong device ....
Re: Rooting NanoPC-T4???
Posted: Tue Apr 02, 2019 8:17 pm
by shivaa
Hi, I think if you root it you can't build it afterwards.
______________________________________________________________________
https://tweakbox.mobi/ https://getappvalley.com/ https://tutuappx.com/
Posted: Wed Apr 03, 2019 3:23 am
by Tiemichael
Not sure about this ...
Currently I am able to root my NanoPC-T4 via adb, but it only lasts until I reboot.
I have not found a way to 'autostart' it ...
Posted: Wed Apr 03, 2019 3:52 am
by v8dave
How are you doing this via ADB? What commands are you using?
I am still looking at the kernel to see if this can be done from there.
Posted: Wed Apr 03, 2019 11:53 am
by Tiemichael
Here are the commands I am using:
adb root
adb disable-verity (requires adb version 1.0.33 and above)
adb reboot
adb root
adb remount
adb install SuperSU.apk (from SuperSU.zip V2.82 - package)
adb push su /system/xbin/su (from SuperSU.zip V2.82 - package)
adb shell chmod 06755 /system/xbin/su
adb shell chcon u:object_r:system_file:s0 /system/xbin/su
adb shell su --install
adb shell su --daemon&
adb shell setenforce 0
adb shell mount -o remount,ro /system (now system is rooted)
When opening SuperSu you will be asked to 'update the su-binary' - don't, or you will end in a bootloop!!!
adb reboot ( ==> no longer rooted)
Once this is done, you can become rooted again by:
adb root
adb remount
Looking at the complicated installation script for SuperSU with app 1600 lines, my current hope is to find (or even create) a CWS or TWRP-recovery for the NanoPC ...
Any other idea???
Posted: Fri Jul 12, 2019 1:01 pm
by amzoun95
There is already support for VPU and mali from Rockchip on linux.
Usually mali fbdev is 20 ~ 30% faster than mali X11 (don't know about Wayland) but there is an RK3399 board that claims a score of 58 (very good indeed, though i don't know which window size possibly Full HD)).
Sarkari Result Pnr Status 192.168.1.1
