Android source won't build.
Here is the error message. I want to build a custom version with added sbs-battery, i2c generic support and some custom apps, so I need to be able to rebuild.
Starting build with ninja
ninja: Entering directory `.'
ninja: error: 'manifest.xml', needed by 'out/target/product/nanopc-t4/system/manifest.xml', missing and no known rule to make it
build/core/ninja.mk:148: recipe for target 'ninja_wrapper' failed
make: *** [ninja_wrapper] Error 1
#### make failed to build some targets (04:04 (mm:ss)) ####
Thanks,
Mike
Where 50G corresponds to 50GB of cache. This needs to be run once. Anywhere from 25GB-100GB will result in very noticeably increased build speeds (for instance, a typical 1hr build time can be reduced to 20min). If you’re only building for one device, 25GB-50GB is fine. Plex Kodi Lucky Patcher
Most users ever online was 106 on Tue Jun 04, 2019 5:48 pm
