docker ce install issue
Posted: Tue Oct 30, 2018 3:06 pm
by seven@7777777s.com
I am using the following:
    rk3399-sd-friendlydesktop-bionic-4.4-arm64-20180921.img
    Booting from a Samsung 32GB EVO Plus microSDHC
    NanoPi M4 Heat Sink with added fan
    NanoPi M4 4GB
I tried a fresh image and an updated/upgraded image
Ubuntu 18.04 LTS 4.4.143
SSH enabled and QT Enabled
The docker ce install instructions from
Get Docker CE for Ubuntu
https://docs.docker.com/install/linux/docker-ce/ubuntu/
I am receiving the following error
invoke-rc.d: initscript docker, action "start" failed.
‚óŹ docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2018-10-30 07:03:04 MST; 18ms ago
Docs: https://docs.docker.com
Process: 4989 ExecStart=/usr/bin/dockerd -H fd:// (code=exited, status=1/FAILURE)
Main PID: 4989 (code=exited, status=1/FAILURE)
Oct 30 07:03:04 NanoPi-M4-00 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Oct 30 07:03:04 NanoPi-M4-00 systemd[1]: docker.service: Failed with result 'exit-code'.
Oct 30 07:03:04 NanoPi-M4-00 systemd[1]: Failed to start Docker Application Container Engine.
dpkg: error processing package docker-ce:armhf (--configure):
installed docker-ce:armhf package post-installation script subprocess returned error exit status 1
Processing triggers for libc-bin (2.27-3ubuntu1) ...
/sbin/ldconfig.real: /lib/arm-linux-gnueabihf/libqtqrcode.so.1 is not a symbolic link
Processing triggers for systemd (237-3ubuntu10.3) ...
Errors were encountered while processing:
docker-ce:armhf
E: Sub-process /usr/bin/dpkg returned an error code (1)
pi@NanoPi-M4-00:~$ sudo docker run hello-world
docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
See 'docker run --help'.
Any suggestions?
Re: docker ce install issue
Posted: Thu Nov 01, 2018 9:43 pm
by ericvh
Default kernel doesn't have some of the right bits turned on.
I have an alternate config file I'm working on here:
https://github.com/ericvh/kernel-rockch ... _defconfig
Docker works, but still working on Kubernetes.
Posted: Fri Nov 02, 2018 7:30 am
by igorp
Docker and Kubernetes should work with this one OOTB:
https://www.armbian.com/nanopi-m4/
Configs:
https://github.com/armbian/build/blob/m ... ig/kernel/
for this kernel:
https://github.com/armbian/build/blob/m ... ult.config
Posted: Sat Nov 03, 2018 6:47 pm
by ericvh
Thanks for the pointer to Armbian, at the very least its a much more "comfortable" environment than the default friendly setup -- particularly for kernel work. In any case, unfortunately I'm kinda stuck at the same spot -- docker works, kubeadm looks like everything is okay, but the master never goes Ready because coredns pods seems stuck in Pending mode:
coredns-576cbf47c7-25vrz 0/1 Pending 0 7m36s
coredns-576cbf47c7-skxc4 0/1 Pending 0 7m36s
I'm basically following Alex Ellis' blog on getting kube up on Raspbian, so there's probably some mismatches. Is there a better source for Armbian kubernetes howto (or better yet specific to RK3399 like NanoPc-T4 and NanoPi-M4 which are the cluster elements I'm going for)
Update -- I was going for Flannel because the blog said something about Weave not working on armhf so I was worried about more general Arm stability. However, installing weave unlocked coredns so now things seem to be working.
Posted: Sat Jan 05, 2019 10:21 am
by sebt3
coredns wont start before you have installed (and fully working) pod network add-on.
See here : https://kubernetes.io/docs/setup/indepe ... od-network
On our system, you have only 2 options weavenet or flannel. The later will requiere vxlan kernel module.
Posted: Tue Jan 08, 2019 3:08 pm
by sebt3
and since flannel seems to be the source of my memory issues causing my rootfs corruption, I would recommand against it
Posted: Thu Jan 17, 2019 7:46 am
by rubyatiy
I'm basically following Alex Ellis' blog on getting kube up on Raspbian, so there's probably some mismatches. Is there a better source for Armbian kubernetes howto (or better yet specific to RK3399 like NanoPc-T4 and NanoPi-M4 which are the cluster elements I'm going for) Love how PhenQ Works
These are not the hypes which you can't describe even though because of that unlocked coredns
