connect dlink 3g modem to nanopi due , i cant see sr0 ....
dear all,
i already bough dlink 3g modem to connect to nanopi due ,
i use the following manual to start the step of installation ,
http://ftp.dlink.ru/pub/usb/DWM-157/Des ... 0guide.pdf
the first step is mnt the package of modem which it will locate in /dev/sr0 or /dev/sr1 , but without success , i can not see it at all , i already try it with armbian os with nanopi due , and it there as i connect the modem i start installation normally , when i get back to original img of nanopi due , i can't not see it
i want to use original os , but how to start installation ...
any advice will be appreciated
thank in advance
regards
DWM-157 is one of the most familiar modems to linux systems. you can easily set it up
run lsusb
then copy the VID & PID to the following command:
usb_modeswitch -V $usb_vid -P $usb_pid
now you should check your device list tree and you may found ttyUSB0 and ttyUSB1.
thank you for replay , i appreciated
regards
