Slow/unresponsive wifi
I've been enjoying developing on the Nanopi Duo. I do a lot of work over ssh/wifi on the device. It will work acceptably for a time, but then feed back with slow to a crawl. Sometimes it can take 30-40 seconds to echo a key press. I've tried this on a wireless network with only two devices. I've tried adding a wifi antenna. It looks like this is using the XR819 radio. It looks like those drivers haven't been touched in a year.
Are others having similar problems? I don't see reports on this forum. Any ideas for a work around or update?
Tawn
Tawn
No workarounds or hacks found in last two years even waisted waste amount of time on it. By many people. There were some small/tiny improvements ...
https://forum.armbian.com/search/?&q=XR819
my search-foo was weak. thanks for the info.
Ohh :) use a USB-WiFi-Stick or Ethernet does work well :)
