How to change DSI Clock
Hi everyone
How do I change the DSI clock?
The following registers have been changed but can not be changed.
・MIPI_DSI Clock Register
・PLL_VIDEO0 Control Register
Thank you.
Hi... I just set up the Pi 2 and the clock is reading 3 hours too early, and the calendar is reading 4-8-15 instead of 8-4-15. I do not see the "clock settings" as hot so I am not sure how to set the calendar and clock to the correct date and time. When searching both this forum and Raspberry Pi 2 help, the responses are for making digital clocks and not re-setting the internal clock on the board.
printed circuit board and assembly
