Hdmi resolution
Can i change hdmi resolution on nanopi m1?
Debian system HDMI resolution is TF card boot partition root directory script.bin decision, the default is the use of 720p-60Hz
Resolution. Boot partition script directory already has several other resolution scrpit.bin, assuming you need 1080p-60Hz resolution,
Just use script / script-1080p-60Hz.bin replace the root directory script.bin:
Hi, Maybe this helps.I haven't used a M1.
Good afternoom, I have an M1 and I'm looking for the boot partition in order to change HDMI resolution but I couldn't found it. In the explorer only appears the folder "/fa" and "/", inside the folder "/" is a subfolder called "root" but inside that folder I couldn't found the script folder. There is another folder called /boot but I couldn''t found it either.
Arround there is a thread that talks about the script flolder but like I said, I couldn't found it.
Please help, I've installed debian 3.4....
Hey @Marron5, how are you? Can you give the path to find the script.bin?, I've been trying to find it even by using the find command in console but nothing.
In total there are 41 users online :: 0 registered, 0 hidden and 41 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 41 guests
