NanoPi Neo Air wake up from suspend?
Hello, I have a NanoPi Neo Air running the FriendlyCore Xenial 3.4.39_20171102 image. I can put the board into a suspend state using pm-suspend, but cannot wake it back up. Ideally I'd like to be able to wake it up using a GPIO pin as an input. Is this possible? I'm not sure where to start.
Thank you
Thank you
http://linux-sunxi.org/AR100
Try attached tool. I only have a binary - not my work - I could wake up a board via IR receiver or a button. Armbian with legacy kernel/Orangepi PC+
It must run on air as well.
Thank you for the reply. I haven't been able to get this to work; I ran it as below and it just sits there after the last line. I get kicked off the ssh session if I type anything. I have an inline USB power meter on the board and the current never drops, and I can ping it successfully from another machine, so I don't believe it's going into suspend.
sudo ./h3fakeoff -s -l PB16 -b PB15 -w 1
str2uint: PB16 -> 00000010
str2uint: PB15 -> 0000001f
do_it:1, config: 0x00011f10 (wol: 000000000000)
apply_foff: start
The Air doesn't have a switch that I know of, so I've got an external switch and LED on a breadboard connected to pins 23/24, and if I'm reading the schematic correctly PB16/PB15 should correspond. Doesn't look like it's getting that far though.
I believe I was mistaken - apparently there is a quick current drop, and based on uptime when I log back in I think it's actually rebooting the Air. Uptime shouldn't reset when waking up from suspend, I would think.
https://h3droid.com/chat-with-us
Ping KotCzarny - he was playing with this tool and will be glad to help you out.
KotCzarny helped me out. The wakeup pin needs to be active low. Thanks!
In total there are 35 users online :: 0 registered, 0 hidden and 35 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 35 guests
