(SOLVED) HOW TO CLONE EMMC (NANOPI NEO CORE)
TRYING TO CLONE EMMC FROM ONE NEO CORE INTO ANOTHER.
I found this link below :
https://github.com/zador-blood-stained/fel-mass-storage
I still don't know if it works since i had to enter FEL MODE which i could not. maybe i am trying in a wrong way.
SO how could i get a clone EMMC of nanopi neo core (taking into consideration it might not have FEL mode)? but if it does then how to enter this mode?
and how to run this clone on another nanopi neo core?
FIRST you need to check where is the EMMC located :
in my case my EMMC was located at /dev/mmcblk1
Then follow these steps : note (if your emmc is 4 GBthen you might need a 8 GB sd card and so ..)
1- boot nanopi from emmc.
2- acces you nanopi through ssh from a pc (windows in my case)
3- plug a USB sdcard reader with sdcard bigger than your emmc.
4- dd if=/dev/mmcblk1 of=/dev/sdX bs=100M.
note /dev/sdX X is for your sdcard could be either a or b or whatever.
after writing successfully on sd-card you could then put this sdcard on the other nanopi and flash it to emmc.
to continue to boot from emmc new image
enter this forum and continue from step 6:
viewtopic.php?f=47&t=2547
