Problem building android image myself
Hello
I would like to build my Android image (to change the boot logo)
I am trying this:
http://wiki.friendlyarm.com/wiki/index. ... e_yourself
git clone https://github.com/friendlyarm/sd-fuse_nanopi3.git
cd sd-fuse_nanopi3
wget http://112.124.9.243/dvdfiles/S5P6818/images-for-eflasher/android-lollipop-images.tgz
tar xvzf android-lollipop-images.tgz
Change the files in rootfs.img and boot.img
apt install android-tools-fsutils
simg2img rootfs.img r.img
mount -t ext4 -o loop r.img /mnt
… To Change Something …
umount /mnt
img2simg r.img rootfs.img
If I unpack boot.img, and repack it (without changing files), it doesn't work. It is not copied to the SD Card. Do you know why?
Thank you!
Michael
I found a way by compiling android from the start, if someone runs into the same issue.
Hello, I have the same problem to compile Android, can you explain to me how you did?
________________________________________________________________________________________________
Mini Militia App Lock 7Zip
