Changing the display in kernel only
I am trying to get a 7.0" Newhaven display to work with the Nano PC T3 Plus and I can't get it to work with the timing changes made to uImage.
I have also made the changes to u-boot but I can't update this on the device for some reason.
Is there an easy way to create an SD card to flash to the emmc that includes the new u-boot and the new uImage? The new uImage I can do as part of the Android build or I can also change this from ADB.
I suspect that both u-boot and the kernel settings must match for the LCD to work. I was under the impression that I only need to modify the kernel for this to work but it seems not to be the case.
As I had suspected, you need to modify u-boot to set your LCD timing. Then you make the same settings in the kernel.
In total there are 21 users online :: 0 registered, 0 hidden and 21 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 21 guests
