freezes Browser
Browser sometimes freezes. And after close process one of core have 100% load. If repeat it (run browser then wait until it freezes) then next core have 100% load.
Q: what is it?
Q2: why freezes Browser?
let's have a check, but how can we re-show it?
Thank you
--Mindee
the same sitiations with WiFi connections and wired.
In GKrellM I look processors load. And use USB HW power monitor.
Surely it'll go down or frozen if you use a NOT GOOD USB power, we have provided the more powerful Power Adapter and USB cable for all microusb power supplying board, the fake cable can't compare with it.
For seriousness, a high quanlity USB cable and power adapter must be needed for 6818 boards, whatever how you get it.
Thank you
-- Mindee
I solved it.
Problem is next:
gst-plugin-scanner run each times when start Iceweasel and take 100% core time
When I killed this process in task manager browser work OK.
https://bugs.launchpad.net/ubuntu/+sour ... ug/1286751
In total there are 16 users online :: 0 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 16 guests
