Nanopi R1
any advise for build openwrt for nanopi r1?
I downloaded and do make menuconfig, but i cant see nanopi r1 hardware.
Thanks a lot
from where did you "git clone"?
for the other NanoPi's are here the instructions:
http://wiki.friendlyarm.com/wiki/index. ... ld_OpenWrt
or download compiled OpenWRT (SD or eflasher) from here:
https://drive.google.com/drive/folders/ ... GkfijH0frC
Thanks @guidol for your answer
I read the wiki and download from:
git clone https://github.com/friendlyarm/openwrt -b master-v18.06.1
make menuconfig
But, in the tarjet devices to compile only exist Allwiner A1/A20/A3x, so cant compile for H3, Im tried o with:
./build.sh nanopi-h3
And no build for nanopi R1,
Any help to compile for Nanopi R1?
how about
openwrt-18.06.1_sunxi-cortexa7_prebuilt_20190109.tar.gz
https://drive.google.com/open?id=1PHtHL ... 2Ss8ezgXDf
nanopi-r1_sd_openwrt_4.14_armhf_20190117.img.zip
https://drive.google.com/open?id=1Bt2YV ... pFrMh3dRbb
nanopi-r1_eflasher_openwrt_4.14_armhf_20190117.img.zip
https://drive.google.com/open?id=1I-ziR ... cbHtbbXvzC
Hello guidol,
Thanks a lot for your advices, I explain better my need, I want use the Nanopi R1 for a project with Openwrt, so I need build with my files and packages.
I have some experience on Openwrt development projects.
I tried
And following the directions in:
But in all the cases cant find the target device Nanopi R1 or H3 architecture for build from sources Openwrt.
Only can build for nanopi-neo and nanopi-m1-plus, here the files generated:
openwrt-18.06.1-sunxi-cortexa7-sun8i-h3-nanopi-neo-squashfs-sdcard.img.gz
openwrt-18.06.1-sunxi-cortexa7-device-sun8i-h3-nanopi-m1-plus.manifest
openwrt-sdk-18.06.1-sunxi-cortexa7_gcc-7.3.0_musl_eabi.Linux-x86_64.tar.xz
openwrt-18.06.1-sunxi-cortexa7-sun8i-h3-nanopi-m1-plus-ext4-sdcard.img.gz
openwrt-18.06.1-sunxi-cortexa7-sun8i-h3-nanopi-m1-plus-squashfs-sdcard.img.gz
openwrt-18.06.1-sunxi-cortexa7-sun8i-h3-nanopi-neo-ext4-sdcard.img.gz
I apreciate any help.
Regards
