Nanohat OLED crashing
I am using the default script from https://github.com/friendlyarm/NanoHatOLED with my nanopi neo2. Running the bakebit script:
~/NanoHatOLED/BakeBit/Software/Python$ python bakebit_nanohat_oled.py
Everything works fine until I try to get to the second page. Once I press K2, the output is:
K2 pressed
Traceback (most recent call last):
  File "bakebit_nanohat_oled.py", line 286, in <module>
    time.sleep(1)
  File "bakebit_nanohat_oled.py", line 240, in receive_signal
    draw_page()
  File "bakebit_nanohat_oled.py", line 156, in draw_page
    draw.text((x, top+5),       "IP: " + str(IP),  font=smartFont, fill=255)
  File "/usr/local/lib/python2.7/dist-packages/PIL/ImageDraw.py", line 209, in text
    *args, **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/PIL/ImageDraw.py", line 233, in multiline_text
    line_width, line_height = self.textsize(line, font)
  File "/usr/local/lib/python2.7/dist-packages/PIL/ImageDraw.py", line 260, in textsize
    return font.getsize(text, direction, features)
  File "/usr/local/lib/python2.7/dist-packages/PIL/ImageFont.py", line 156, in getsize
    size, offset = self.font.getsize(text, direction, features)
SystemError: error return without exception set
Has anyone run into this? Thanks
You need to install it first, execute the following command in the Ubuntu core system:
# cd NanoHatOLED
# sudo -H ./install.sh
# cd NanoHatOLED
I've already done that. The screen works fine until it tries to go to page 2 of the display
I'm sorry, it's an issue. Now you can fix it this way:
cd ~/NanoHatOLED/BakeBit/
sudo git checkout master
sudo git pull
sudo reboot
Most users ever online was 42 on Fri Jul 15, 2016 1:04 am
