NanoPi M2a Android source
Sadly the wiki-page of the Nanopi M2a is still empty at this time, with the exception of three pictures.
Therefore I would like to know if the the source code for android for the M2 is compatible with the M2a and if the instructions on the wiki-page of the M2 are applicable to the M2a.
Hi
M2A wiki will not update, you can see M3 wiki. M3 and M2A in addition to the CPU is not the same, the other is the same, if you want to burn the system, please use the m2 system.
chensy, can you check the Android 4.4 sources on MediaFire for M2, the file after download is corrupt.
