core4418:can't flash from SD to eMMC /invalid partition info
on module core4418, I accidentally erased the internal eMMC.
Using the latest eflasher image [s5p4418-eflasher-android-lollipop-20181217.img]
on a sd-card, I can't flash the eMMC.
The SD card boots up, but the UI displays an error message: "Invalid partition info ret = -1"
The SD card is ok in general. I flashed my device using this card many times.
How can the internal eMMC be fixed to be flashed again?
Thanks in advance.
While you are testing and developing I would recommend the development image. Also just to make sure, i are you just looking to use balenaOS with out the cloud service? or do you intend to use balenaCloud as well?
Tutuapp 9apps Showbox
Most users ever online was 825 on Wed Aug 28, 2019 3:18 pm
