2nd SD card what does it do?
Sorry if this is obvious, but I've not managed to set up my new Nano Pi's yet and will try to do so later this week, but I was just curious what the 2nd SD card does on the Nano Pi2 ?
I use 2nd sd card slot for media, so I can switch between many SD cards with 1. movies 2. music 3. files/documents.
Its mostly external storage.
ok thanks
I have a question, how do you access the second SD card?
When I insert it and run Debian from the first one, I cannot access it from the OS. I get an erros message saying "The specified directory '...' is not valid.".
I hope you can help me.
Abel.
Abel.
Hi Abel, I need to confirm with you about the following three points:
1. what was the file system of the microSD card which you inserted into your Pi 2 board?
2. Did you test it under Debian or Android?
3. What commands did you run?
Hi, thanks for your replay,
I had inserted a microSD card on the first slot and I was running Debian from it. Actually, that microSD card is the one I recieved from you.
In the second slot I had another microSD card, with no OS, it just had a c program file (which I put there in my PC before).
The problem is that when I insert it in the NanoPi2, I cannot access the files in the second microSD card. I get the error I told you before.
Actually, I'm not able to acces even the files in the OS microSD card.
