Adding LAN port over GPIO
Hi every body, i have 4 pieces of Nanopi 2 but i need ethernet connection to HUB, could i have any solution ? Because this is my first time working with SBC, and i trust nanopi has better perfomance
Hi. Are you sure it's the NanoPi 2 or any other NanoPi Neo2/S2/DUO2/... The NanoPi 2 is old and isn't sold anymore.
Best to use a usb to ethernet adapter with the NanoPi 2. I don't know of the availabillity of drivers for it.
I don't see any ethernet break-out pins on it.
Good luck.
i have enc82j60 adapter for it, but still unuseable. but thank you for your information nico
U can buy and micro USB Ethernet adaptor that already has 3 additional USB ports attached to it for about 4 to 9 US dollars
Sarkari Result Pnr Status 192.168.1.1
Most users ever online was 5183 on Tue Jan 21, 2020 11:30 am
